I want to define a beam for my basement and roof gable wall.
AUGURD
Hello.. I want to define beams for my basement curtains and roof gable wall, but how do I do it in idecad? How can I define my panels fi12-14 and select only the basement curtains fi8?
Re: Idecad defining beam
"AUGURD":14pmex8m" said:
Hi.. I want to define my basement curtains and beams for my gable wall, but how can I define my idecad beams? How can I define my panels fi12-14 and select only basement curtains fi8? ?
Hello, -If you only want to use 8-inch longitudinal reinforcement in basement shears. You can manually edit in the Shear Reinforced Concrete Design dialog (It is effective in the analysis model of basement curtains. As a result of the editing, the reinforcement may not be sufficient.) In the reinforced concrete dialog, using the Ctrl and shift keys, you can manually edit
-Roof gables are constructive elements. You can enter additional load. Good work
Re: I want to define bond beam for my basement and roof gable wall I want to use bond beam not only as the load of gable walls but also to extend the column and define the basement curtain as bond beam, not panel. Is there a way to define a beam in İdecad?
