Re: Hotkey Hello, Command repetition cannot be assigned to space bar. But; -If the "Show menu with right button" option is disabled in the General Settings dialog, it works as a command repetition when the right mouse button is pressed. (If the option is not inactivated, Ctrl+right button works as command repeat.) -The command will be repeated when mouse wheel (scrool) is pressed. Good work
