I need urgent help please
Hello. Your structure is x=26 meters but you have defined two axes x=3215 meters away from the origin point. In the formwork plan, those axes are also dimensioned. If you delete the axles, the problem you mentioned will be solved. Note: You are solving a tunnel formwork project, you need to make a solution with the semi-rigid diaphragm option taking into account the earthquake effects on the flooring.
