I modeled a pedestal for the turbine
smsenturk
Hello everyone, good work. Attached I modeled a pedestal for the turbine. Floor height is 8m, columns are 80x80cm, floor thickness is 125cm, floor thickness is requested by the company. I will need your comments about the model, I have not done any beamless flooring before and I have modeled such a structure for the first time in the program. Thanks in advance...
Re: TURBIN STRUCTURE ANALYSIS Hello My suggestions: If we choose from the wizard --Fringless cork flooring, --Semi-rigid diaphragm, --Ductility You need to choose High, --Screen A12 or A13. This solution is not correct because your project does not have a screen. Unver ÖZCAN
