I made the raft it saved, this time it doesn't save??
evanes07
good day, the raft foundation was not equipped in its current state, I made all the basement and floor slabs 15cm, when I analyzed, the raft saved, then I got it back. It was 12cm. It did not save the raft in the analysis, so when I made the same slabs to 15cm and analyzed again, the raft did not save it... I've had it too, it must be a very interesting problem, what could it be related to? Also, what does it change that 25/175 dimensional columns are curtains? If I make a curtain, will it save, if so, can the columns turn into curtains directly? I would be very grateful if anyone with knowledge could help me..thanks..
"evanes07":20d43d15" said:
good day, when the raft foundation was not equipped with this form, I made all the basement and floor slabs of 15 cm, when I analyzed it, I saved the raft, then I got it back. It was 12 cm. ...I've experienced this when I've made other kinds of games with the beams, it must be a very interesting problem, what could it be?
Hello, In the project you added, the K107 and K108 beams are not connected to the S69 and S70 columns. recreate it.
"evanes07":35jy64op" said:
I've experienced this when I've done other kinds of manipulations with beams, it must be a very interesting problem, what could it depend on, can you help me?
It's normal for the results to change depending on the changes you make to the beams because the beam bearing moments Rescue/non-recovery situations are affected depending on the , loads and the frame system it creates. If I make a curtain, will it save, if so, can the columns turn into curtains directly? [/quote] The design of columns as curtains is related to the column's aspect ratio. According to the regulation, this ratio is 1/7. The fact that the column is a curtain changes the reinforcement design. It also affects the choice of R coefficient according to the ductility level of the structure.
I saw that beams 107 and 108 are not connected, but when I analyze in this state, it does not give an error about it? I couldn't explain it fully, for example, I am looking at the raft, it saves at first, then I make an arrangement about the columns, the raft does not save, then I undo the same arrangement without touching anything, while saving the raft at first, it does not save the raft this time in the same order? It's a very strange problem, have you encountered it before? In addition, in this arrangement, what can be done most logically to save the raft without changing the thickness of the foundation and remaining the main reinforcements of the foundation? In other words, how would it make sense to arrange a column curtain with one side too long compared to the other side like this project? can i have your suggestions? Also, is it possible to convert 25/175 columns from shortcuts to panels?
"evanes07":3c3tlrcz" said:
I saw that the beams 107 and 108 are not connected, but when I analyze this, it does not give an error about it? I am taking back the arrangement. While recovering the raft at first, it does not save the raft in the same order. It is a very strange problem, have you encountered it before? Also in this order, what can be done most logically to save the raft without changing the foundation thickness and keeping the basic main reinforcements? How would it make sense to arrange a column curtain with one side too long compared to the other side? Can I get your suggestions?
-There is no situation like you mentioned in the project you added. Install the 8 version of the team viewer program from the link below and call us. Let's see in the way. Also mentioned in the previous message in the project When the beam problems were fixed, the raft did not give any warning of inadequacy in flooring.
Is it possible to convert 25/175 columns from a shortcut to a panel?
Delete and re-enter needs.
