Hello ide team and guests. I have problems in the build and sell project that we need to start immediately. I think I will overcome it with the contributions of you, dear friends. My problem with the raft flooring is as follows; * In our structure, which is not excessive in terms of its characteristics, the problem of the cross-section thickness and the amount of reinforcement exceeding a very high amount in the raft slab? * In addition, I should mention that I use max 14 reinforcements so that I can evaluate my stocks. Best regards to the ide team and friends who will help me with my problem
Re: THE APARTMENT HAS A FULL RAFT FLOOR Dear insmuh03, There are important data entry errors in your project. You should check the geometry and correct these errors first. Apart from that, the raft thickness and reinforcements seem normal for this structure. There is a problem with additional reinforcements on the raft. In the place where the big curtain is (p3-p2), curtain element inputs are made on top of each other. Therefore, there is a problem with the elements connected here. I could not understand the k13 beam on the 1st floor and the k27 beam attached to it. Likewise, the beam K35- k39 - K46, which seems to be tangential to the column, is also incomprehensible. S2- S5- S23 beams are also not restrained in the other direction. You have one curtain in the Y direction and this curtain does not form any frames in the Y direction. Check your loads; balcony loads insufficient landing and stair loads are insufficient. You cannot design a single rib console floor. The flooring behind it also needs to be ribbed (and continuous). This way, you may have a chance to merge the columns. You should definitely overhaul the carrier system. Surely there is something to be done. I've written this much for now, I couldn't examine the rest because I had to quit. But I suggest you fix the things you absolutely need to fix first.
Re: THE APARTMENT HAS A COMPLETE RAFT FLOOR Thank you for your advice and interest, Mr. Yılmaz. *First of all, although I did not understand some of your recommendations, I tried to apply the part that I could understand, but the mat flooring was still a problem. I'll redo it and fix it again if needed. *Although I am an engineer who is still at the beginning of the road and continues to gain experience, I also know that I still have a long way to go. *I will apply to the forum if it does not happen again after my editing is finished. Thanks to everyone interested.
