"tekt":113n2dth" said:good day, I'm new here. I couldn't solve the excessive reinforcement at a point in the base. I couldn't upload the project here because it is high-dimensional. .It is necessary to define axis-to-axle and column joint connections as much as possible Sent from my SM-G610F using Tapatalk
thanks in advance for your help .file on the link"unver":2zf61h86" said:Hi Upload your project in the link belowYou do not have permission to view link Log in or register now.
First of all, thank you very much for the information you have given, Mr. I'm posting the link. If I'm wrong or wrong, I would appreciate it if you could check it."unver":1wlv9z66" said:Hi. My suggestions are; --Make the foundation height of 60 cm at least 80 cm for this building, --Make the column height at least 370 cm on the ground floor, 35 cm on the narrow sides of the column, 30 cm on the other floors, --Your ground floor is not rigid, remove the ticks, --The stair is not supported, -You can reduce the live loads on the 5th floor and remove the wall loads Unver ÖZCAN
