I HAVE DIFFICULTY WITH DWG IMPORT
btemel52
EVEN IF I DOWNLOADED THE ATTACHED DWG FILE TO ONE PLAN, I CANNOT IMPORT TO IDE WHEN I IMPORT, LET'S IMPORT MY NEW PROJECT OPEN. OR WITHOUT OPENING A NEW PROJECT? FILE ONE PLAN WITH SUCH AS GROUND FLOOR PLAN AS IMPORT ET'm DE FILE disappear A KIND FILE not GİRESUN OBJECTS to calculate SCREEN bring THREE DIMENSIONAL am sending PLEASE FILE from YOU EVENT TO BE IMPORT THIS FILE I would be pleased if BANANA SHIPMENTS AND IMPORT EDMEYİŞİ my REASON NET is ACABA thanks in advance
Master, there are many parts in architecture, so there are point drawings on the plane, so ide perceives all of them. What you have to do is work a little on the architecture. You must move the floor plans to the point 0,0,0 from the intersection of the A and 1 axis in the coordinate plane. Type 0,0,0 in the line command, click enter and you will find the coordinate 0,0,0. Then explode the floor plan and move the intersection of the A and 1 axis to 0,0,0. When I import it in ide 6, I saw that the layer loses its properties, the line scales are getting corrupted or I don't know these settings. That's why I'm using ide5. When you import ide5, you need to enlarge the dimensions 10 times. I did what I told about them in the attached file. If anyone has another solution, I would like to learn a better and easier one. Good work.
Mr. bbase52, the reason why your dwg file is not seen after import is probably accidental drawing or copying of some objects very far away from your drawing in Autocad. These distant drawings push the zoom drawing boundary far enough to see these drawings, so your floor plans look like dots. In the attached file, I cleaned them, opened the 1st and 2nd floor plans and arranged the dwp drawings for you by placing them on the appropriate floors. If you encounter such a situation again, I am writing the steps I have done so that you can edit. * import dwg. * Zoom in until you see the drawing that looks like a dot with the zoom window. *Open the selection window and select the drawing. (do not select all, we do not want to select the distant objects that we want to delete) *Then press the invert selection icon (so that the distant objects will be selected) and delete. (we deleted the remote ones) *Now when you draw zoom, only your drawing will be visible. *Measure an object. You will see that it is 100 times bigger. Reduce it 100 times with the scale command. (Making the first value 0.01) *Select all. Enter the Move command, give a base point and enter x=0 enter, y=0 enter in the coordinate box. The drawing will be moved from the base point you provided to the coordinate (0;0). *Zoom drawing again. (note: the attached cde file is in 6.054 format.)
Ms. Arzu, can you take a look at this dwg, I'm opening the dwg drawn in one color, but I can't import the colored version and the pen thickness given. why could it be. I sent it as a rar file because I couldn't paste it as a dwg and dxf file.
"saridurmus":123pi0x1" said:
Ms. Arzu, can you take a look at this dwg, I'm opening the dwg drawn in one color, but I can't import the colored and pen thickness version. why can't I paste it to the clipboard as a dwg and dxf file, as a rar file I sent it.
Hello, I was able to import your dwg file in version 6.0054. Import takes a long time, I guess that's why you thought it couldn't be imported. Good work
"saridurmus":21o87evy" said:
Ms. Arzu, can you take a look at this dwg, I'm opening the dwg drawn in one color, but I can't import the colored and pen thickness. I sent it.
Hello, after importing your dwg file in the program, all objects were fragmented with the object shred command. The reference was reduced 100 times with the scale command and moved to the origin point. And then each drawing was blocked within itself. The project is attached.
Levent, can you tell me the problem? They prepared the same project with a single pen, I opened it easily, but when I open it, it writes that the idea will close itself, and it makes me close it. I'm asking to follow a path in other projects
Mr. Sarıdurmus, if the file is exactly the same , except the line color and pen thickness, if the file you can't open and open comfortably is the same [/b][/u], send the other dwg and let's test it. We cannot understand that it is not. "Your dwg file could be imported on 3 different computers in our technical office. (between 45 seconds and 2 minutes 10 seconds depending on the config.) There was no error and shutdown."
I am sending the files to you guys. I have three drawings in it, only one color pen thickness is not given, it opens after waiting for about 1.5 minutes. The other two (Pen thicknesses and colored) do not open and give an error. good work.
Hello there; The black and white drawing is loaded in about 15 seconds. Colored drawings are loaded onto the track in 25-30 seconds without any problems. I am sending the ide files attached... good work
My way of importing and moving to the origin is the same as engineering. I don't know an easier way either. However, I couldn't help thinking that I was behind. I convert it to autocad 2000 version and import the file later. I know it's easier and hassle-free. Architectural objects also experience shifts from time to time. I think everyone experiences this.
there is no difference in the application, I am also processing with autocad 2004 dwg or dxf. Sometimes it gets stuck while importing.
The recent scans of acad 2010-2009 versions etc. the unnecessary drawing by the person working on the architecture extends the import time. If you bring the processor power to 100% in the Vista operating system, it will heat up a bit, but its speed will increase 2.5 times. I believe it will work faster if this is done in idecad. delete empty layers command should be developed (except idecad orj layers and-or we should see the unused layers with a list option (with a command like layer edit) maybe the architect knows, but for static layer furnishing layer is unimportant..), I change the layer and now I put the whole architecture in the aa_architecture layer, I block it and turn it on and off as I want. (again, a suggestion - to see the layer I want in a faded state as in the sketch mode, freeze it and work on it with ctrl, but normally it doesn't hold any ends.) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . This is how I'm working at the moment) this is a real XP vista types machine ram cpu etc ...it varies a lot. The import time sometimes takes 3 seconds, sometimes it takes 30-35 minutes and the user thinks that he is waiting and locked. We always see the dwg creator working in the origin or the acad file full of flying objects, unfortunately, we cannot tell the drawer what we want, so we have to do the idecad object fragment, erase and move with scale (on a machine without acad), I think if questions are asked to increase the speed during import eg:[ Should /b] be taken to the origin-how many times it should be reduced or enlarged(the scale will be understood in 1-2 tries)- should it be converted to a single layer (not standard)-to a single color-remove the scans.... after all, like idecad We use it and it uses almost all cad functions as if someone with idecad bought it in autocad. on top of it using architectural or static aspects. these are undeniable successes, I think, with our constructive support, better versions...good work.
In the next interim update (v6.0055), we have made optimizations to speed up work especially in intensive 2D drawings. We will offer it to you in 1-2 weeks. Opening the sample dwg file has been reduced from 2min20 seconds to 10 seconds. Please continue to share with us the situations where you have problems with this type of speed. Since the primary purpose of the program is not to work on 2-dimensional intensive drawings like Autocad, special accelerations are required for such situations.
When I create the structure with the data I got from the 2D architectural project arrow, a rigid diaphragm is formed as much as the number of floors as I have attached. just why. I am attaching the project. I am also sending the dwg file that I got the plan.
Your floor inclination angles are defined as 5 degrees, so the problem occurs. Probably before the tiles were defined, the tiling angle setting remained at 5 degrees. If you select your tiles and set the angle to zero degrees from the properties menu, the program finds it as a single rigid diaphragm.
In 5 versions, when I transfer the drawing as dwg and call it with autocadde insert, the drawing comes in one-to-one scale without a unit. There is no problem. I need to reduce the drawings I transferred to 0.03937..... How can I solve this problem?
In idecad, column beam connection shear safety B error is not considered much in other programs. In ide cad, when 3 or 4 beams are stuck in a 25 to 50 column, it gives a B ERROR when misalignment is not given. Other programs do not give such an error. What is in idecad that is not in other programs? Or is idecad solving this part more securely? thank you
