I have defined a ladder but it is not visible in the plan
mkrts88
I defined a staircase, but it does not appear on the plan, should it appear on the floor plans, I could not see any data about the staircase reinforcements in the analysis.
In order to receive the stair reinforcement drawings, you need to define a reinforced concrete calculation axis. It is explained in detail in the attached video.
Stairs are not drawn automatically when you receive a formwork plan. After taking the ladder detail drawing, the desired drawing can be copied to the formwork plan with 2D editing possibilities.
I made it from the draft of the ladder command, I knew that when I did it with the field addition method, it was necessary to create an account axis.
Yasin, I have one more question, after you define the reinforced concrete calculation axis of the related model, it will give its load to the columns it is stuck in, right? So is there a definition error?
