I Get Pivot Error On Matrix Reduction
sadikcafer
Hello there; While doing analysis I stop analysis and get pivot error in geometry check and matrix reduction. When I checked the geometry, I did not encounter any problems. A simple project in the project is not a troublesome project. I would be glad if you help. The project is attached.
Hello. Your foundation is faulty, delete the entire foundation, reconstruct it from column to column, or make a raft foundation. (Analysis is completed when the foundation is deleted.) Ünver ÖZCAN
Hello, You are having problems with the nodes of the continuous foundations connected to the P3 and P4 curtains in your model. -One piece of continuous foundation is entered under the curtains. You should enter the continuous foundation piece by piece, taking into account the curtain knot points. -Select model shell element by selecting all curtains. -You also make a phased construction calculation in your model. There may be problems with the nodal points in ideCAD version 7 when the phased construction calculation is made with continuous foundations. We fixed this problem with ideCAD 8. If you are not going to do a phased construction calculation, I suggest you turn this option off as well.
