I get multiple rigid diaphragm detected alerts
mimarss
First of all, take it easy guys, I have a few questions. I get the warning that more than one rigid diaphragm has been detected in the basement, does this pose a problem or does it indicate a situation. As for my other question, when I am adjusting the level of the landing beams, I get the warning of unsupported beam or incorrect beam level, when I give the warning of unsupported beams, the system cannot be resolved and the analysis is closed, if the warning of incorrect beam level, the system is solved, I am waiting for your help on this, I am adding the project.
Re: help about the project
"mimarss":1n8151fy" said:
first of all, take it easy guys, I have a few questions, I get the warning that more than one rigid diaphragm has been detected in the basement, is this a problem or a situation? As for my other question, when I am adjusting the level of the landing beams, I get the warning of unsupported beam or incorrect beam level, when I give the warning of unsupported beams, the system cannot be resolved and the analysis is closed, if the warning of incorrect beam level, the system is solved, I am waiting for your help on this, I am adding the project
Hello, First of all Update Ver 8.504 from the link below
-Multiple rigid diaphragm warnings -50 cm. Delete the eaves and re-enter in Ver 8.504 version -The K145 beam is given a +145 cm level in the basement floor. hasn't. Identify the beam by giving a negative level from the ground floor. -Adjusting the upper level of the P53 curtain on the basement floor, which is given a -90 cm upper level, zero and 90 cm. Define the first part by giving a negative upper level on the ground floor. Good work
Re: help about the project Mr. Levent, good night, I rearranged the project in line with your advice, as a result, the rigid diaphragm problem disappeared, but even though I gave negative elevation to the beams, it continues to give an incorrect beam level warning in the geometry control. There is no problem in the reports. what would you recommend, regards
"mimarss":err1516v" said:
levent, good night, I rearranged the project in line with your advice, as a result, the rigid diaphragm problem disappeared, but even though I gave negative elevation to the beams, incorrect beam elevation in geometry control continues to give warning, there is no problem in the reports, what do you recommend about this regards
Hello again, the elevation of your K21 beam is not compatible with the columns. You do not need to give an upper level and elevation to the columns as you have defined the beams by giving a negative level. In the attached project, the elevations of the K21 beam and the columns to which it is connected have been adjusted. Good work
Re: help about the project Hello Additionally --You can take the basement floor as a rigid floor, --you can remove the curtain beams on the basement floor. Take it easy Unver ÖZCAN
