hello friends, the project I have uploaded; I encounter many errors when I copy 3 normal floors. I get column beam B error especially in the mezzanine and other floors. How can I get rid of these errors without changing the size of the columns. Also, there is no meaning to the Nmax error in the basement floor.
[/ quote] Hello, Nmax error on the basement floor is a result of the solution together with the foundation and superstructure. When the height of the foundation is 60 cm and the beam is 25/60, there is no problem. Some of your beams on the mezzanine floor do not provide maximum clearance controls. The dimensions of these beams, which are 30/30, are insufficient For column-beam shear safety errors (B), the attached link will help you (item 9) You can try to overcome the problem by increasing the beam width instead of the column size.
