I get a stapling error
bagcihan
Hi, I'm getting a stapling error after the last update. I was not getting this error in the old version, how can I solve this problem?
Re: stapling error
"bagcihan":3esg47yy" said:
Hi, I am getting stapling error after the last update. I was not getting this error in the old version, how can I solve this problem?
Hello, Stapling problem, TBDY It is caused by the design-based punching stresses calculated according to 2018 exceeding the concrete design tensile strength. Stapling controls, punching reinforcement calculations and reports were made within the scope of the 2018 Earthquake Regulation in the Ver 10.20 version. You can review the studies carried out in the Ver 10.20 version from the link below.
To overcome the problem of stapling in the raft foundation; The thickness of the mat slab can be increased.If the stapling problem is in the outer columns and there is no amplification, it can be amputated .Concrete class can be increased. Column/wall size can be increased. Stapling reinforcement can be used in the Column-Shear Properties/Punch Reinforcements tab... (Make the drawings of the selected punching reinforcement automatically it doesn't work. You have to do it yourself by reviewing the raft punching report and using the 2D possibilities) Project notes; -According to TBDY 2018 article 3.3.1.1.a), the basement floor should not be considered rigid. - Unable to create mesh in tile D01. Redefine the flooring. -The bottom edge of 1 arm of the ladder has no foundation. The upper edge of the 2nd arm is also not connected to the upholstery. Good work
Since I got a stapling error in the raft slab, I solved the problem by adding the stapling reinforcement with closed stirrup strips to some columns, but I can't get the stapling reinforcements in the drawings. I think it should appear in the basic application plan. Do I have to draw? If so, how should sample drawing be made?
"mesutkoku":3k7qy28i" said:
Since I got a stapling error on the raft slab, I solved the problem by adding a punching reinforcement with closed stirrup strips to some columns, but I can't get the punching reinforcements in the drawings. I think it should appear in the basic application plan. Do I need to draw it? If so, the sample How to draw?
