Good day, I could not solve the deflection problem of the 3rd floor K28 beam in the attached project. I am waiting for your advice, opinions and suggestions.
Log in or register now.
First of all, I would like to thank you for your advice and suggestions.I will consider all of them.Also, do you think I chose a high ductile system and got a carrier system coefficient R = 7. Is it also suitable? or should I choose a mixed system? Can you give general information about this subject?"unver":3nykd8b4" said:Hi My Suggestions --PUT COLUMNS AT THE INTERCEPTION OF G AND 6 AXLES, --In terms of earthquake Turn 25/60 beams to the exterior facades, --Thus, the beam with deflection error is also straightened, --Rib beams center the columns --The rib beams do not protrude more than d/2=32/2=16 cm from the column, -- Supporting the ladder together with the structure -Place flooring on the elevator curtains to carry your machine, Take it easy Ünver ÖZCAN
