I don't have a save as SAP2000 data button
emreyaykin
HELLO FRIENDS; I WANT TO COMPARE ON A PROJECT BUT MY SAVE AS SAP2000 DATA ON THE PROJECT TAB IN THE OLD VERSION IS NOT IN THE SAME PLACE? AM I THE ONLY LIVING THIS?
Re: I DON'T HAVE THE SAVE AS SAP2000 DATA BUTTON??? Save the project as 7 versions, transfer them from 7 versions and compare. When you transfer to 7 versions, the wall load in 8 versions can be calculated automatically based on the floor height, so if you save as 7 versions, see that the wall definitions of 7 versions and 8 versions are the same and transfer them to the handle program. In the projects that were built in 7 versions and opened in 8, the wall loads are transferred to 8 exactly. The above-mentioned situation is valid when transferring from 8 to 7 and care should be taken.
Ismail Bey, do I understand correctly that we will have to install 7 versions at the same time? So, will we be able to do this in the future without the need for version 7? .
"emreyaykin":1exersc3" said:
Ismail Bey, do I understand correctly that we will have to install version 7 at the same time? Will we be able to do this in the future without the need for version 7? .
There will be no such opportunity in the near term. If it is, you can only do this through 7 versions. Transferring to the SAP program and changing the data between the versions of the SAP bring us serious development costs. While ensuring data compatibility with old versions in the transition of even our own program between versions is a development burden, such data compatibility for the "elamin" program is for us in the short term serious luxury.In future versions, we can reevaluate our users' priorities and market demands, and we can put them on the agenda.
Thank you Ismail Bey, that will be enough. We have no doubt that you are constantly working for the best of you. Surely it will be added again. Good luck with
I should state as an idea and request that it would be a serious feature to make it in the sap version so that we can provide checks.
"kaankoc":3c2oiv0l" said:
I should mention as an opinion and request that it would be a serious feature to make the sap version so that we can do checks
You can do checks. 8 versions do not transfer data directly to the sap. Follow the steps below to verify . 1) Enter the project you will checkout in version 7. 2) Transfer your project from version 7 to the handle, so you have tested the accuracy of 7 versions 3) Open the same project with version 8. 4) Compare the results of the handle with the 8 versions.
