I couldn't solve the ni<60 error
erbilsancaktar
Dear friends, I have a work with a half basement, I have been working for 5 days, I have redrawn it many times, but some mistakes have not been fixed. ni<60 error -- I defined a 50 cm curtain for the filled place in my basement and a 30 cm curtain for the neighboring parcel. I'm stuck on the weak floor warning. I am getting a relative floor offset error on the mezzanine and the 1st floor. I changed the column sizes, I couldn't get rid of the error, there were pursantaj errors on it. It is a project that should be submitted to the municipality in order not to be stuck with the 1 October regulation. Is there anyone who can help? I want to see my mistakes and learn the reasons. I couldn't upload it because the file size is 28mb.
"erbilsancaktar":1a7mch0q" said:
Dear friends, I have a work with a half basement, I have been working for 5 days, I have been trying for 5 days, I have redrawn many times, but some mistakes have not been fixed. ni<60 error -- 50 cm curtain on the filled floor in my basement and the adjacent parcel I defined a 30 cm curtain. I was stuck on the weak floor warning. I am getting a relative floor offset error on the mezzanine and the 1st floor. I changed the column dimensions, I could not get rid of the error. I couldn't get rid of the error. There were coinage errors on it. A project that should be sent to the municipality to avoid being stuck in the 1st October regulation. Is there anyone who can help I would like to see my mistakes and find out the reasons. I couldn't upload because the file size is 28 mb.
Hello, The information given in the following link may help you.
thank you Mr. Hakan Mr. Hakan, I fixed most of the errors from the links you provided. I even saw that I could solve it in different ways. But I came across some errors. If I post the link would you be able to take a look? Thank you from now.
Hello My Suggestions --The ground floor and the foundation were wrong by adding the basement floor, --The width of some columns was increased due to low rigidity on the ground floor, --The calculation saves, --There is a B error in a column, --Stairway braces should be corrected incorrectly. Unver ÖZCAN
