Hi, -You get min thickness warning on raft foundation. The distance between the columns (Ln/30) is checked in the thickness control. In cases where there are no columns in the raft, the thickness If the thickness is sufficient, you can interfere with the "Reinforced Concrete Calculation Axle Edit" command to the line of the reinforcement axles -clear opening for thickness control.
