I couldn't hang the curtain cut safety issue
mimarss
Hello everyone, first of all. Whatever I did in the 2b+z+5-floor hollow block project I prepared, I could not handle the shear force problem in the p36 elevator curtain (even though I played with the reinforcements and the section), I am waiting for your help. Have a nice day. The file is attached.
Re: curtain shear safety issue emergency help I reviewed the analysis settings and only the rigid floor mark remains in the 2nd basement. When you pull the curtain 30 cm, there is no problem.
Hello, you have given the rigid basement number incorrectly. In the analysis settings, enter -2 instead of -1. The design shear force of the curtain does not provide the control depending on the curtain dimensions given in TDY. The superstructure seems to increase the shear force of the basic interactive solution curtain design. Adding columns to form a continuous frame can solve the problem, instead of making a large curtain that carries almost the entire structure in the middle of the building.
Additionally, in the analysis settings, you can choose not to tick the "apply ductile materials to rigid basement" line. If you do not select the option, the part of the wall in the rigid basement will be exempted from the TDY high ductile shear force control. Whether or not to implement this option is entirely at your discretion as the project maker.
In my 3b+z+4nk project, after the analysis, I got the error that the cutting safety is not provided in the basement curtains, I could not solve the problem even though I increased the curtain dimensions...
"mimarss":15def5vq" said:
friends, first of all, hello to everyone. Whatever I did in the 2b+z+5-floor hollow block project I prepared, I could not remove the shear force problem on the p36 elevator curtain (even though I played with the reinforcements and the section), I am waiting for your help. have a nice day. The file is attached. [url =https://drive.google.com/file/d/0B7JCXaEkmdPxd1NaR0VuUkdnNlk/view?usp=sharing]https://drive.google.com/file/d/0B7JCXa ... sp=sharing[/url][/ quote] Erase the curtain, throw a beam, and the problem will be solved :)
