Re: B1 Irregularity Hello, Columns and curtains that are not connected to the diaphragm in the program are not automatically included in the floor cutting area in B1 irregularity. Due to the small diaphragm area on the ground floor, your column cutting area is lower than the 1st floor. If you want to include column areas that are not connected to the diaphragm on the ground floor, you can define them manually in the Floor Parameters/Irregularities tab. When the floor parameters dialog is open, you can access the help document related to the dialog by pressing the F1 key. B1(You can review the document linked below about Weak Floor Irregularity.
Some notes about the project: -1 floor P021 e Enter the upper elevations of the P023 curtains as -90 cm in line with the beam B036. -1 floor edge defined under the cantilever beams. You can see it in the geometry check. Good work.
