I couldn't fix the cut-off safety error on the curtain.
Hello,
etc. You can upload your project as a single piece to one of the file upload sites and give the link. Also, the project was made in demo, is it within your knowledge? You cannot open the project in the normal version for later output.
I just drew it in the demo, I'm still in the working phase, thanks for the site you provided..
Also, is there a situation where the soil unit weight can recover the soil stress in case the ground safety stress does not recover on the raft? I think there is always such a situation in the basics..
Two curtains in the project do not provide cutting security, I could not fix it, does anyone have any information?
"guraykose":15z4w8nn" said:
something like purse warfare, like a cut head, like a mouthful of vaccine, a word that makes honey with oil.... )
Why would he ask how he asked for help in a very neat language Sent from my SM-G925F using Tapatalk
I think our friend is asking about the methods of the program users to get rid of this problem instead of talking about the formula caused by this problem in the directing.
Hello. My suggestions: --remove all joint fixations, --solve the project as semi-rigid diaphragm Unver ÖZCAN
Thank you Ünver Özcan, when it is solved as a semi-rigid diaphragm, the curtain errors are corrected, but this time the raft reinforcement says insufficient, I do not understand how we fix the joint points. Also, if the forum officials think like guraykose, they can state it. ..Thanks..
Take it, we'll answer it to the best of our knowledge. If there is no forum, shoot it privately Sent from my GT-I9190 using Tapatalk
How can an arrangement be made about the curtains, is it not possible to eliminate the cut safety errors without changing their dimensions? Could it be helpful to play with the dimensions of the beams to which it is attached? Or is it necessary to change the way the beams are connected in that region, that is, their geometry? the reinforcement arrangement does not fix the errors in any way..is there any friend who can help?
