I couldn't create the rotary ramp as I wanted
Apokalips
[*]Good day, I need to make a vehicle ramp with an inclination of 18% in the project I have stated in the appendix. However, I could not create it the way I wanted. Can you make suggestions?
I didn't manage to do it the way I wanted with the slant tiling. Also, the vehicle will descend and I think the ramp is very useless.
Isn't that what you want? What is your hesitation? I deleted some objects to reduce the file size. The slopes look reasonable according to the triangle you drew.
"NYILMAZ":1gk1ueov" said:
isn't what you want? Do you think I should make only those beams as curtains instead of the beams I put at the beginning of the ramp?Also, how much is the minimum thickness of the ramp flooring according to your front view since it will be used for vehicle passage and where can I access the iron details of the ramp flooring?
The ramp height is not too high where the beams in the starting area are located. I recommend making curtains. I chose 20 cm in the file I sent you about the thickness, I do not recommend making it less than 18-20 cm. Analyze it and have a look. I recommend increasing the width of the lower beams as well. You can even connect the K89 beam to the middle of the bow and define a curtain under it. Accordingly, if you wish, it may be possible to reconstruct the ramp and better organize its elevations and slope.
