Hello there; According to the conflict check, there is a conflict between two red colored elements. The program does not create automatic joining in the ridge regions where the lower and upper heads of the scissors need to be connected to each other. The conflict error you are getting is for this region. By extending the plate in the ridge area, you can use scissors and bolts between the lower and upper head and the plate. You cannot create this in the current version, the R&D work continues. You have to intervene on the drawing. You have to enter a joint detail in the drawings as in the attached image. Good work.
