I could not fix the stapling problem
yunussacikk
hello, I couldn't fix the stapling problem in only 1 column. I defined the column header but it didn't work. I can't enter the column header correctly. Can you help me?
"yunussacikk":33wgcq53" said:
hi I couldn't fix the stapling problem in only 1 column. I defined the column header but it didn't work. Can you help me enter the column header correctly?
Hello, If you are going to apply the column header on site, enter it in the program. For details and minimum conditions, refer to TS500. 1. Switch to basic mode. 2. Click on the column header. Click on the symmetrical column header 3. Select the column and define the title 4. You can edit the title properties as in the screenshot. After analysis, stapling saves.
The raft slabs that you entered in your project as two pieces and in different thicknesses are not connected in the analysis. We will report the issue to arge for review. It would be appropriate to enter the raft slab in one piece and in the same thickness.
