I could not enlarge the lugs from 4 sides on single foundation
gunner
have a nice day. In the project I have done, I was asked to turn the foundation I designed as a raft into shoes. only the dimensions were too big for me, 4 m*4 m. Is it possible for me to take it to a more appropriate size? Also, I couldn't enlarge the shoes from 4 sides because there is an existing structure on the right of the columns on the 5 axis. I am stuck with the ground safety tension. I would be very happy if you could help me with this subject.
Your wall loads are too much. Moreover, you have given both wall and live load to the beams. Likewise, your flooring loads are too exaggerated. It is not unusual to have such results.
"NYILMAZ":3fr273xt" said:
Your wall loads are too exaggerated. Moreover, you have given both wall and live loads to the beams. Likewise, your floor loads are too exaggerated. It is not abnormal to get results like this.
hello, my floor heights are 4.5 meters Because the wall load was not 0.8 t/m, the wall load increased up to 1.5 t/m. I only added wall load to the side beams. I removed the live loads from all the beams. I also reduced the slab thickness from 15 cm to 12 cm. Since the coating will be 3 cm marble, it will be approx. It corresponds to a load of 0.315 t/m2. I bought 0.35 t/m2 directly. With these processes, I could only reduce the shoe sizes from 4m to 3.5m.
