I constantly raised the foundation, I couldn't beat the stretch
insmuhturker
GOOD DAY TO EVERYONE, GOOD JOBS. HOWEVER, IN THE PROJECT I ATTENDED, I CANNOT STRENGTHEN THE SECTIONS WITH THE CONTINUOUS FOUNDATION, BUT I CANNOT STRENGTHEN THE SECTIONS BUT I USE 50 CM RADIUS, BUT THERE IS A VERY GOOD SOLUTION. /b]
Re: Despite constantly growing the foundation, I could not overcome the stretching Hello; First you need to fix a few definition errors in your project. 1- Since you do not have curtains in the X direction, choose the frame system for the X direction. 2- You should define the column that you defined as a polygon column as a group curtain. 3- You should review a 19cm full wall defined in all of your beams. 4- Review the wall load defined on your foundation beams and delete the unnecessary ones. Your project, which has been arranged considering these situations, is attached. Please review the project for the continuation. Best regards.
