I cannot analyze.
rahmigul
I saw that similar problems were encountered in previous titles, but still, what I read was not enough to solve the problem. I contacted the place where I bought the program and they said there might be a vertical continuity problem. I checked and couldn't find anything like that. He said that if I change the minimum object length to 1cm, maybe it can be solved, it still isn't. If I don't have to deliver urgently, I'll make it from scratch, but I don't have time. I will be glad if you help me.
Analysis is being done in the project I sent in the attached file. But I haven't been able to review your entire system. But when I look at it, I can say that you have some mistakes. For example, your basic data entry is incorrect. You must define a continuous basis from the start and end point of each curtain. Your carrier system behavior coefficient is incorrect. You had errors in your node joins. Your connection to a beam and curtain is mainly due to the inability to analyze. Also, on the f axis, at the intersection of k551 and k552 beams, a piece of beam remained. (on each floor) Also, if I were you, I wouldn't enter the basement curtains by defining a separate floor. This will only make your job harder. There are a lot of articles about flood curtains in the forum, I recommend you to read it. I'm not going into loads etc. Sorry, I was a little busy so I took a quick look and wrote something. Hopefully it benefits your business. Good luck with...
