I can't view IDECAD help file in XP..
fmwaral
Hello to everyone. I cannot view most of the titles in the help file of IDECAD in XP. I do all the updates on the OS periodically. But I was not successful in any way. I tried it on Win 7 RC version. I saw the Help titles and content, this time "WHAT IS THIS?" feature did not work. I finally tried it on Vista Ultimate from a friend of mine. I got the result. Does anyone have a similar problem or have any suggestions for a solution? Good work..
Hi, I'll try to find a solution if you add some screenshots here showing the problem for XP. For Vista, "What is this?" A plugin needs to be installed to display the contents of the help files. Because they announced that they removed the plug-in that displays the help content in the Microsoft Vista system. You can see the details in the article below. You can download and install the related plugin from the same link.
This is the screenshot. Good work
I just realized something.. All of my OSes were in English. Could it have anything to do with it? Because the vista of the friend I mentioned above was TR..
No help english Tried on XP and Vista operating systems. However, even if the language is English, language support must be made in Turkish. In Control Panel/Regional Settings, also select Turkish as the language. There are Turkish characters in the related link in HTML help. If there is no Turkish language support, the path specified by those characters may be invalid. You try...
I had done all the localization work. Everything was set to Turkish. Yesterday I installed it on my own Turkish Vista home basic OS. it worked pretty well. I'll manage for now. Thank you.
I forgot to mark the checkbox in the picture where you mentioned. I'm putting the picture here in case it might be useful to others. It started to work without any problems on an XP Pro version with SP3, whose native language is English, which was later translated to Turkish with the language pack. :)
