I can't solve the project
erkanka
hello, I'm officially screwed on my first big project and I'm going crazy.. Where do I go wrong, it keeps giving errors, I would be grateful if anyone could take care and help, thank you... file:
Thank you for your interest, Mr. Hakan. I have corrected the vertical continuity errors. Most of the errors in the geometric analysis are due to the fact that the beam width is 20 cm and the elevation difference on the ground floor (20/72) beams... My main question is how is the carrier system? as it is, it gives a pursanaj error. Even though I delete and re-enter the beams I mentioned several times, it does not improve. What could be the reason? Thanks
"erkanka":1xrwiqlv" said:
thank you for your interest, Mr. Hakan. I fixed the vertical continuity errors. Most of the errors in the geometric analysis are from the fact that the beam width is 20 cm and the elevation difference on the ground floor (20/72) beams... How is the load-bearing system? Some beams are overwhelmed with excessive reinforcement and naturally give an error. Even though I delete and re-enter the beams I mentioned several times, it does not improve. What could be the reason? Thanks
If you add the final version of the project, we will evaluate your project.
I did not see the project, but I understood from the articles that the narrow side of the beams is 20 cm. The regulation says that the narrow side of the carrier elements (horizontal and vertical) cannot be less than 25 cm. If the narrow side of the sections is brought to 25 cm, some problems are solved.
ide the project in its final form While I can solve it in 7, I get many geometric and analysis errors in ide 8. On the ground floor, where the basement curtains do not continue, I naturally throw beams, I get a warning of incorrect beam panel combination and it does not improve. I have to throw a 72cm beam from the ground floor S03 column to the console. I would appreciate it if you look again and guide me..thanks
