I can't select on all floors
mkrts88
When I say that there is no selection on all floors, the p07 curtain is not selected on some floors, I checked whether it is on top of each other, and there was no problem, can you take a look? Model
Hello, Ground,1st,8.9.10. The p07 curtain knot points have slipped on the 3rd and 3rd floor. You can delete the curtains on this floor and copy them from the other floor.
"mkrts88":3o63e42l" said:
when I say "selection is not available on all floors", p07 curtain is not selected on some floors, I checked to see if it is on top of each other, and there was no problem. Could you please check?
Hello, there are walls on top of the P07 curtain. P07 curtain can be selected on all floors when the walls are deleted one after the other. Also, there is no need to enter a wall where there is a curtain. In version 8, the location recognizes the curtain. When geometry control is performed, objects are listed on top of each other. Examine and fix errors in geometry control. Open wall layers. Examine walls. Other issues in your project : 1. Curtains on some floors are not modeled as shells, on others as shells 2. P20-21-22 curtains on the basement floor are not defined in the third basement. There is a vertical discontinuity in your structure 3. There are very small angle shifts in your structure. For example, P10 curtain is exactly 90 The degree could not be entered 4. There is a trim problem on the wall between columns S11-S12. There are very small angle shifts on the walls. Do not change the trim method. By increasing the trim problem is solved. 5 In the analysis settings, the option to carry all earthquake loads with hollow shears is selected. Your building is not a structure that is all carried by hollow curtains.
