Hello there; I did not see a problem with the modeling of the elevator curtain in your project, when we look at the reports, it is seen that the sections of the problematic areas are insufficient. As a solution, you can increase the thickness of your elevator curtains, increase your concrete class, or in general, you can reduce the effects on the elevator curtain by adding other curtains to the carrier system. Apart from these, I would like to point out two problems that stand out at first glance in your system: - Your basic definition is wrong, as follows; If you wanted to make a raft with beams, it is imperative that the main beam passes under all columns, and the columns should never step on the raft. If you wanted to define a slab raft, this time there should be no outer foundation beams. - Your acceptance of a rigid basement seems to be problematic because your basement does not seem to have enough perimeter curtains. Best regards.
