I can't receive reports and drawings
mimarss
Hello, I have completed the final version of my work with Idecad 8.504 with 8.61, but I cannot receive reports and drawings. In 8.504, I can get the report and printout of a small project I have drawn before, but I cannot get the report and printouts of the project I have sent in the attachment. I tried to get a report in 8.504, but the system that recovered in 8.61 did not recover in the previous version. I would be glad if you help.
Hello, I have reviewed your project. We have received the necessary note about not receiving a report. Your problem may be due to defining T-profile slip joints. These joints can be made without any notching. To avoid overlap, you can change the d2 parameter in the plates tab. This parameter tells how much to shorten the secondary beam from the center of the beam. You can use the combinations of the beams defined with the secondary beam command for easy operation in the connection of secondary beams. When you select the combination by hovering over one joint of the secondary beam group you have defined and holding down the "ctrl" key, all the connections of the related secondary beam group will be selected, thus making it easier for you to process. Best regards...
Hello, One of the reasons why the sections that are insufficient at 8.504 are sufficient at 8.61 may be the corrections made at the deflection limit. Improvements were made to the deflection limit in version 8.61. Posting version 8.504 of your project will help me find the reason for the difference. When I saved the project you sent as 8.504 and analyzed it, I saw that the reason for the inadequacy was deflection. As I mentioned, this inadequacy has been eliminated due to the corrections made at the deflection limit. Best regards...
Thank you very much for your interest, Mr. Oğuzcan. The solution you wrote in your first message worked for me. When I shoot the secondary beams one by one with a macro, there is no problem, I can get both drawings and reports. I wish you good work.
