The problem has been identified and fixed in the next update. Thank you for your report."gyatko":3tnzlv18" said:hello, after the analysis, go to the Drawing menu key, retaining wall drawings, retaining wall expansions, click all of the new layout blocks and give a name, then switch to the layout, add a layout block, select the block from the layout blocks menu, select the layout the program closes when I try to place it on top
