I can't identify two typical beams for cassette flooring
ramazanerdem
hello there are two ribbed slabs to the right of the cassette slab.....i am getting typical beam error in geometry check..how can i define two typical beams to cassette slab...
"ramazanerdem":2lb268s1" said:
hi there are two ribbed slabs to the right of the cassette slab.....I get typical beam error in geometry check..
Define typical beam on failing slab with define typical thread and make typical beams continuous Also define the adjacent tiles of the cassette slab with the cassette slab command
how can I define two typical beams for cassette slab...
You can define one typical joist for each direction in cassette slab.
