First of all, I wish you a good day and good work... When I try to get a column application in a steel-reinforced concrete mixed project, the white screen does not appear... I deleted the floors and took them one by one. I solved it that way, but the forehead-to-growth junction macro that I used in the reinforced concrete column-steel beam junction sometimes fails to print out the axles. sometimes the macro looks crooked....Is it the combination wrong or is there a point that I missed....
Re: I can't get the steel drawings, it's crooked Hello, The combination used in your project 'forehead and gusset joint' is not suitable for reinforced concrete column steel beam. For reinforced concrete column steel beam use 'guse joint'. When you use 'guse joint', the joint will not be crooked and its drawings can be taken. When the concrete column or steel column application plans are taken, the drawings are correct. If a plain white or solid black screen appears, make the title settings from the drawing settings. The version you are using may be the old version. You can use the link
