I can't get the retaining wall plan drawing.
Re: retaining wall
"ahmet_divan":3b2f2tfe" said:
I can't get the retaining wall plan drawing. Only sections are displayed.
Did you run the "Retaining wall analysis" command from the Analysis menu and did a retaining wall analysis? If you did and you still can't see the reinforcements in the Retaining Wall Reinforced Concrete dialog and drawings, add your project.
After doing retaining wall analysis, I take cross-sectional images. However, I cannot get the plan drawing to indicate the wall lengths with different heights. Do I need to make the plan image manually in autocad?
"ahmet_divan":fnqy25mn" said:
After doing the retaining wall analysis, I get the sectional images. However, I can't get the plan drawing to indicate the wall lengths with different heights. Do I have to manually create the plan image in autocad.
Retaining wall plan drawing image It is not prepared automatically.You can make the arrangements you need by using the 2D drawing editor of the program or in another CAD program.
Re: Iron diameter and soil safety stress. In this project; - I couldn't get 16 gauge iron to be accepted on the well foundation front stirrup. 18 and 14 are accepted. - Although I entered 16.1 for the soil safety tension, the report shows 20 t/m2. Thank you in advance for the answers.
Hello
"ahmet_divan":fyvebvt1" said:
- Even though I entered 16.1 for the soil safety stress, the report shows 20 t/m2
The soil tension is taken as 20 t/m2 on the basis of KT2, if you change it to 16.1 t/m2, the reports are corrected.
