Good day, I can't get all the rib openings on the ground floor, it only gives the opening of two floors, I wonder what the reason could be
Log in or register now.
When I made the 25 cm aperture 32.5, I got the jig and arranged the distance according to 25 cm"HakanŞahin":1w9aor0w" said:Hi, The rib slabs you mentioned have a 25 cm opening. It is not edited.
my brother, because I couldn't find a solution to my problem, I asked it here, if you know, write an answer, tell me the solution, let's apply it, you will be an engineer beneficial for the environment"mkrts88":1mdcih80" said:social engineering example
sorry bro, I wrote with a momentary limit sorry"mkrts88":1aakauwf" said:my comment has a positive meaning. If you look at my previous comment, I suggested the same solution, I think you misunderstood me
