I can't get the ground floor column application plan
Eralp Özer
I CAN'T GET THE GROUND FLOOR COLUMN APPLICATION PLAN. I do not have such a problem on the same computer in different projects or on other floors.
Re: I CAN'T GET THE GROUND FLOOR COLUMN APPLICATION PLAN I can't get the vertical openings of the curtains in the same project.
Re: I CAN'T GET THE FLOOR FLOOR COLUMN APPLICATION PLAN Hello. You can also divide the floor into two, it's up to you that I won't comment on whether to accept it as rigid or not. If you mark the basement as rigid in the floor settings, the problem is fixed. Good work...
Re: I CANNOT GET THE GROUND FLOOR COLUMN APPLICATION PLAN Hello. Have a geometry check on the ground floor. Delete all errors that the program finds in this check. When deleted, the colon application plan can be taken. Then you re-enter what you deleted. Unver ÖZCAN
