I can't get report in attached project
Re: İdecad Report Problem (Urgent)
"vtutkal":mq7gzzoi" said:
I can't get a report on the attached project, can you help? The project was drawn with version 7.022 (2007 earthquake code)
Hello, We can get report in your project It may be a situation originating from your computer. Delete the files under the "C:\ProgramData\ideCAD" folder. Your problem can be solved. If you cannot see the ProgramData folder, it may be in a hidden location. You can make it visible by ticking the "Show hidden files and folders" option in the "Folder and Search options" section. If the problem is not solved, you can install the teamviewer program and contact our Bursa office.
