I can't get past the B1 irregularity
Re: I can't get over the B1 Irregularity problem You haven't added the project, but let me tell you that if you define a wall on the basement curtains in architectural mode, your problem will most likely be solved, it's the most common mistake.
B1 IRRORITY PROBLEM EMERGENCY HELP PLEASE I GET CONTINUOUS DOUBLE REINFORCEMENT AND INSUFFICIENT REINFORCEMENT ERROR IN B1 IRRORITY AND STAIR FLOORING I ADD THE PROJECT, LOOK AT IT AND PLEASE HELP.
1. To troubleshoot double reinforcement in the stair slab, enter the properties of the beam supported on the slab. Check "This beam bears cantilever slab". 2. The form of the slab that did not meet the deflection requirement was not defined correctly. Define as I show in the screenshot, but your project has carrier system selection problems that will force dimensions. 3. It is normal to have B1 irregularity in your project. There is a serious loss of space between the 3rd basement floor and the 2nd basement floor. Examine the B1 irregularity report. You will see the status. In terms of total curtain column areas, the lower floor is less than the upper floor. Therefore, B1 irregularity occurs. I think changes should be considered on the architectural project.
