I did it, I realized that the small project was revised 7 times. There were beams on top of each other, I deleted them, there was a tile on top of each other, but I can't find it, there is a warning but the tile is not visible So i will draw from scratch"TheBEaST":3kg4cmah" said:you need to check the geometry and correct the parts you need to fix.. there are many mistakes
Check the geometry. Fix the typical tooth errors. If you add the project, Check it out, we'll help."EVCEN":3jc6wt19" said:I got this error too, now idecad has stopped working, I can't take only rib beam expansions, how did you solve this error, can you help?
