I can't get a report
The report can be obtained without any problems in your project. The existing iderpt.tmp file should normally be a rewritable file. There may be a situation on your computer that is preventing this. For this reason, you may have problems with different projects. For solution: 1.) You can restart your computer and try again. 2.) Alternatively, you can delete the "iderpt.tmp" file under the "C:\ProgramData\ideCAD10" folder yourself.
I wrote possible solutions in my previous message. Did you apply?
"HakanŞahin":2p8whgc7" said:
For the solution: 1.) You can restart your computer and try again 2.) Alternatively, you can delete the "iderpt.tmp" file under the "C:\ProgramData\ideCAD10" folder yourself.[/quote ]
