I can't fix beam drawing error.
siminn
Hello, I could not see any errors in the reports as a result of the analysis in my project. but when I take the drawings, for example, in my ground floor beam expansions, my reinforcement lengths are given as -, the font sizes are different in some beams. I can't find where my mistake is. When I talked to the technical service, some of the columns in the project did not coincide with the axis intersections of the nodal points, Also, some of your sub-basement panels are seen as the elevation of the upper floor. In order to correct these errors, it will be easier for me to enter information in this way. First of all, wipe the basement perimeter curtains and beams. It was stated that I had to place the column nodes at the axis intersections, draw the Beams and place the slabs. Then I had to draw the basement perimeter curtains. It was stated that I had to inactivate the divide line with intersections in the auxiliary toolbar while drawing the basement perimeter curtains. I tried to do what was said, but I still get the same error in the drawings. I am sending the project attached. I would appreciate it if you could review my project and help with this as soon as possible. I am attaching my project. Good work.
Hello, You sent your project to the technical service by e-mail. After the date of the message, you said that the problem was solved with the suggested method. If the problem persists, you can contact Technical Service again. Good work
Thank you Mr. Levent for your interest. I fixed the problem later in the drawings as you said. I wish you good work.
