ness_odens
how to define hidden beam in the program beam height cannot be less than 30 cm
If there is a beam in my opinion, there is no hidden beam. Designs of this kind are nothing but deceiving the people themselves or those who control them together... I don't know what programmers say, but this is my opinion as an engineer."ness_odens":2xmpw9i3" said:how to define hidden beam in the program, beam height cannot be less than 30 cm
You know, sometimes such things are done to flooring in classical systems, I answered in that sense Mr. Köse, what you said is called tape beam in our country (this is also in the flooring command ) Anyway, I accepted it and get a cover for me"insmuh_gk":gvptgbwa" said:Fixed beam or hidden beam expression is used for these bands, which are entered equal to the floor height defined as the support band in tunnel formwork projects or cork flooring systems. Nedimcim! G.KÖSE
Good afternoon. I want to use backing tape in raft foundation, how can I enter? can you help me. The tape joist in the tiled option is in the off state. Thanks in advance"NYILMAZ":7jcl6qxo" said:You know, sometimes such things are done to flooring in classical systems, or I answered in that sense. Mr. Köse, what you say is called a band beam. (this is also in the tiling command) Anyway, I accepted it and get a cover for me"insmuh_gk":7jcl6qxo" said:In tunnel formwork projects or cork flooring systems, this is entered equal to the floor height defined as the support band. bands, fictitious beam, or hidden beam expression is used Nedimcim! G.KÖSE. So 1-1 you win.
"batuhann28522":3jpa0yd8" said:Good day. I also want to use a support tape on a raft foundation, how can I enter it? Can you help me. The tape beam in the tiled option is closed. Thanks in advance[/ quote] Band beam is a constructive element.It is not included in the analysis model.The number and diameter of reinforcement is determined by the user.It is generally used in tunnel formwork systems to reinforce the free edge of the slab.
