I entered the tiles without creating the tile edge Creating tile edges is not a method we highly recommend.I entered the tiles without any intervention in the project you sent with the 8.504 demo."deraliye42":2tasw9af" said:thank you for your answers. it happened after I drew the tile edge. I still don't understand why it didn't happen before because there are curtains in the other corners, but the tile was formed without drawing the tile edge.
It wasn't until I drew the tile edge."Ismail Hakki Besler":8imopxlu" said:I entered the tiles without creating a tile edge. Creating a tile edge is not a method we highly recommend. I entered the tiles without any intervention in the project you sent with the 8.504 demo."deraliye42":8imopxlu" said:thank you for your answers. happened after scratching the tile edge. I still don't understand why it wasn't happening before because there are curtains in other corners, but a tile was formed without drawing a tile edge.
thanks for your interest. I upgraded to 8.504. However, the reason why I did the panel-panel combination is the minimum screen size requirement (min 25cm*175 cm) s I had to tie the curtain up to the axis of the curtain for her to cry. If not, it gives a warning in geometric control. but I guess this curtain size requirement should not be a very important thing."HakanŞahin":mtcenfrc" said:It is not necessary to enter a floor edge on the side of the curtain . 8.103' The reason why the tile cannot be entered in the tile is not defined correctly. The panel-panel intersections are not defined correctly. Continue the other curtain where the curtain ends. Match the node points to each other. Example image of the error: In 8.504, facilitations have been added for such cases. You can enter tiles without making any changes in the fields you mentioned. For this, update to 8.504 demo. However, your curtains will still not be modeled correctly. Be sure to correct curtain-curtain intersections. Watch our training videos or ask in the forum for issues that are not understood in data entry. Link for 8.504 demo: Link for training videos:You do not have permission to view link Log in or register now.
You can make the curtain in different thicknesses.The point here is that the end point of the first curtain and the starting point of the second curtain that continues to it are not the same, some of the curtains are overlapped."deraliye42":278u1j8c" said:. However, the reason why I did the panel-panel combination that way was that I had to combine the curtain up to the axis of the curtain in order to meet the minimum curtain size requirement (min 25cm*175 cm). If this curtain size requirement is not a big deal, it should not matter.
