How did you see where the ladder is supported? In Help for solution with structure Support conditions for solution with structure: If solution is made with the assumption of semi-rigid diaphragm, the structure - ladder is solved together as a whole In this case, the objects to which the stair edges are connected are determined by the options given in the dialog. Connected to beams, columns, panels, floors, foundations : Specify which objects the stair edge will be considered attached to, respectively. Fixed support : The stair edge is considered as a fixed support. Supporting distance : The edge of the stair Give the amount of distance that will be valid for its fastening on the support. it says. Can Ide officials explain this a little more? For example, what happens if we click on the fixed support.
