onurceylan
Hello, I am attaching my project, I want to analyze, but the system gives a warning that it cannot be resolved. What could be the most obvious reason? I will be glad if you can help in detail, let it be koaly...
Dear Onur, We are trying to guide you as much as we can here, we are trying to help you save a lot of distance in a short time by sharing information. IdeYapı employees are also trying to solve and answer questions and problems directly related to the program. However, neither of us is in the situation of doing the job of another engineer, nor is our project solving situation out of question. As I mentioned before, there are many in your project. There are important problems. You haven't done much anyway that you want support from us. You have entered something similar to classical architectural geometry. Now you expect us to data the project. More importantly;"onurceylan":1f9tbb1e" said:Hello again, if possible, can you solve the problems in the project I sent and send it to me? Even if it becomes analyzable, it's enough for me... I will be glad if you can help and send it... Take it easy...
"onurceylan":1f9tbb1e" said:I deliberately entered the beam sizes differently because the contractor friend wants minimum iron. Even in a 2800 m2 building with a large console, dilatation, uneven geometry and different floor heights, it would not be like 80 tons of iron not passed he wants something ridiculous. Also, when I pass the tears with the slab edge, the program wants the slab thickness to be 21 cm. That's why I used the slab gap, I think it's a program-related issue. It is not desired to cross the slab gaps with a beam either. not "absurd", I observe that the contractor is in a hurry to fulfill his wishes. This method is completely opposite to my understanding. After all, it is not in my mind, but the contractor is. "" is not possible. My mission is not to correct the mistakes of others, but to inform them about mistakes and prevent them from being eliminated and repeated. Project management requires responsibility. I think you need to make more careful solutions until you feel this feeling and competence. Best regards... Good work, take it easy.
