During the analysis, the system cannot be resolved, I am getting the harvest, we tried to fix the error from the node point, but it did not work, I would appreciate it if you are interested, good work
Re: SYSTEM CANNOT SOLVE ERROR Hello 20 cm. There are balcony slabs with openings. Floor meshes cannot be created because the floor openings are too small. The opening of the slab edges is 25 cm. Define it to be. The problem will be solved. Good work
Hi, there are balcony slabs with 20 cm. openings. Floor nets cannot be created because the slab openings are too small. The problem will be solved. Good work
Instead of doing this, wouldn't the same result be obtained if the slab finite element width was reduced to 20 cm? Doesn't the program take into account element widths below 25 cm?
