I am getting a nodal analysis error in tile
insmuhturker
GOOD DAY EVERYONE. I GET AN ANALYSIS ERROR CAUSED FROM A NODE ERROR ON THE DF01 FLOOR ON THE FLOOR CEILING. I DID NOT FIX THE PROBLEM IN ANY WAY. THE ERROR CAN ARRIVE ONLY WHEN THE FLOOR IS DELETED.
Re: ANALYSIS ERRORS FROM NODES Your flooring mesh length is 80 cm, if you reduce it, it solves it. I think 80cm is a little too big.
"insmuhturker":33ph2nsi" said:
MRBLER GOOD DAY TO ALL.FLOOR FLOOR CEILING AFFORDABLE FROM NOVEL FAILURE ON DF01 FLOOR FLOOR FLOOR IT IS ELIMINATED CAN ANYONE HELP ME WITH THAT, THANK YOU
Hello, -Flooring properties Adjust the finite element width to 25 cm. The analysis will be completed. For accuracy of calculation, we recommend that the finite element widths of floors, curtains and rafts be reduced and analyzed. Leave a space of 1 cm between the lower edge of the arm and the end landing. In this case, you can define separate support conditions for the lower arm and the upper landing. Or you can define a floor instead of the floor landing and a staircase with an intermediate landing. you can create. You can get information about the creation of stairs and the determination of support conditions from the links below. -Creating the ladder
-Defining the ladder support conditions
Good work
