Hello friends, in a place with a snow load of 1.4 kN / square meter. I want to design a project that will use sandwich panels. The span between the columns will be 8 meters and the distance between the beams will be 3.6 meters. What kind of beam would you recommend I use? I made the following analysis in idecad using IPE 220 for columns and beams. However, the cut seemed a little big to me. Waiting for your suggestions guys. How can a more optimal design be made? How can I get past that span? I used the hol command to analyze. I'm thinking of getting another column right in the middle of the building, but I couldn't do it with the hall command. I will also enlarge the crosses. I'm thinking of welding the joins.
