Hello My suggestions; Even if there is no problem in the calculations, there is no such thing as I will fully comply with the architectural project, if necessary, you should intervene in the architectural project. --It should be essential to create a framework in such reinforced concrete projects, 3 axis, on the left and right side facades of the building, there is no frame on the upper floors, --Things not to do even if the calculation saves: - Console as in S4 column (K40 beam), likewise S25 column K41 beam, S2 column K50 beam, - It is not appropriate to cross a span of 3.30 m with a beam of size 25/60 (K38-K30 intersection) There is also such a situation on the 3rd floor ceiling, - to fit 15 cm of 35 cm wide K68 beam on S11-S7 columns.[/b ] --3. If you are not going to use the floor ceiling, you can reduce the floor live loads and remove the wall loads.
